I like the quality/results of cloud rendering from Navisworks. Easy with great results, but the cloud rendering ignores views with "enabled sections" and the resulting rendering is not "sectioned". The view renders in desktop rendering mode, but the results/quality are quite different. Is it possible to render Navisworks Section views in the cloud? The workaround I've used is to export section views from Revit, but that means I have to export several nwc files from revit. Any advice/answer is appreciated.
Andrew,
Thanks for using cloud rendering. Navisworks have a limitation to export the information of the sectionbox to cloud rendering, so the section box can not be supported on cloud rendering.
Dear Sandy / Autodesk
Wanna know if there is any updates on the above issue since 2015?
Thank you so much.
BR
Max
Thanks Sally.
Hope this issue can be fixed since the quality in cloud rendering is really good. It's sad if it cannot do in sectional views.
BR
Max
Guys,
I am also trying to render a section view using Navisworks 2018 version, seems this has still not been fixed,
Can anyone suggest any tips and trick.
You quick support will be highly appreciated.
Mohammad Rukhsar
+xxx-xxxxxxxx
@max wrote:
Thanks Sally.
BR
Max
Still same issues while creating sectional cloud renderings in 2020 as well.
A workaround that takes quite some time if you have a lot of objects in the model is to manually hide all the objects that cover the surface you want to put the section. Not ideal but could work in some cases.
