Interactive Rendering is a real-time photorealistic-rendering environment that makes creating beautiful images and turntable animations super-easy. Simply drag and drop lighting environments and materials onto your project, adjust your camera, and then click the render button. With the power of cloud computing, we take the guess work out of what your final images and animations will look like — what you see in the view port as you work is what your final rendering will look like.
Although it is part of Autodesk A360, Interactive Rendering only works with the Autodesk® Fusion™ data type at present. You can access the feature set by clicking the ‘Try Beta’ button located in the rendering mini gallery view from your Autodesk A360 Dashboard.
Using Interactive Rendering is super-easy. Simply drag and drop lighting environments and materials onto your project, adjust your camera, and then click the render button. When you launch the beta, you will see a help screen outlining how to get started.
The Interactive Rendering workspace is divided into several zones:
Use the navigation tool pallet to orbit, pan (drag + alt), zoom (drag + shift). The home icon resets your model. You can also switch to full screen mode by clicking the zoom icon.
To change the appearance of how your scene is lit, simply drag an environment from the environments list on the left to your scene. Predefined examples include a selection of studio environments as well as different outdoor daylight conditions. Use the slider to adjust the rotation of your environment within your scene. A green bar indicates the currently selected environment for your scene.
A wide selection of high-quality materials is available to help you visualize the look of your design. To apply a material, drag the material from the material pallet on the left over to the desired part of your model. Choose from metal, metallic paint, paint, plastic, glass, rubber, wood, leather, stone, fabric, and carbon fiber material types.
Three camera parameters are available to help you refine the look of your rendering.
To create a collection of favorites, click the star icon below any environment or material. Selected items will be added to My Favorites. To remove an item, click the star icon below the item you’d like to remove.
Use the search box to search for available environments and materials.
Click the plus icon to save a shot of your current camera settings. Snapshots are collected in the shots bin. At present, snapshots only save your camera position.
To create a cloud rendering from your scene or shot, click the carrot icon and follow the instructions in the rendering dialog. During the beta period, it is free to use the Interactive Rendering feature set and create cloud renders at standard quality under one mega pixel. Cloud renderings and turntable animations at higher resolution require cloud credits. The dialog shows your available cloud credit balance and estimated wait time to complete your rendering job.
To create a turntable animation, click the turntable icon in the render menu. Expected wait time and required cloud credits will be displayed in the dialog box.
The settings you select become your default settings. You can add a render to your collection with your default settings by clicking the word Render. As you hover over the button it will indicate the number of cloud credits require to render.
At present, only the Autodesk® Fusion data type is supported.
During the beta period, it is free to use the Interactive Rendering feature set and create cloud renders at standard quality under one mega pixel. Cloud renderings and turntable animations at higher resolution require cloud credits. Your available cloud credit balance is shown in the render settings dialog.
Interactive Rendering will work in any web browser that supports WebGL.
Your feedback is very important to us, so don’t forget to let us know what you think in our beta forum.
This document outlines how to use Interactive Rendering. It will be posted to the beta forum along with a series of how to videos.
A little legal stuff: ‘Try’ means you agree to the Autodesk 360 Beta Preview Terms and Conditions.
Solved by ruffoc. Go to Solution.
Solved by DarrenP. Go to Solution.
i am not seeing a try beta button anywhere on the a360 dashboard
DarrenP
Hi Darren,
Right now the interactive rendering beta is turned on only for the Fusion data type. If you are using Fusion and your can't see the 'try beta' link in in your Autodesk A360 Dashboard, let us know.
Best
Chris
Hi Duncan
Thanks for your feedback. We are on a mission to make cloud rendering easy and accessible to everyone!
It made sense however to expose interactive rendering for the fusion data type as a beta to start. We are looking at other data type and as soon as we have a timeline we will let the community know.
In terms of turning Interactive rendering into an App, there are no plans at present but this is a good idea and we will add it to our idea station
Chris
@ruffoc wrote:
Hi Darren,
Best
Chris
i found it
DarrenP
Many users have are asking for detailed instructions on how to access Interactive Rendering from Autodesk Fusion. We are working on ways to make Interactive Rendering more discoverable, in the mean time here are a few steps to help you get started
Step 1. Launch Autodesk Fusion
Step 2. Click on the view options button
Step 3. Click on the Info icon for any file and select ‘Open details in A360’
Step 4. Select the ‘renderings’ icon and then click the ‘Try Interactive Rendering Beta button’
Hi @asraf.kafaouin,
You are right, the A360 user interface has changed and the ‘Try Interactive Rendering Beta' button is missing. We will be adding it soon to this new UI. For now, if you want to user Interactive Rendering, you will have to follow these steps.
- On the A360 page, go back to Home.
- Click on your profile icon and from the window choose "Go back to Old version"
- Once you have the old UI, you can access it as before.
