A360 Forum
Welcome to Autodesk’s A360 Forums. Share your knowledge, ask questions, and explore popular A360 topics.
Uploading dwg
3 REPLIES 3
325 Views, 3 Replies
Uploading dwg
Hei
I'm new in A360.
I tried to upload a 2d DWG. ACA 2012 fil to my project.
every thing is ok until it's finished to upload, I can not open/view the fil. on line.
I'm using Google Chrome
3 REPLIES 3
Bud_Schroeder_ADESK
Hello Yanwei,
Once you upload the file it needs time to do what we call translate so that you are able to view it. Can you try it again and let us know if it's still not working?
Thanks for posting your question and looking forward to hearing back from you on if you can view it now.
Bud Schroeder
AutoCAD Customer Council Beta Programs
Autodesk Inc.
Join the AutoCAD Customer Council Beta Program.
in reply to: Bud_Schroeder_ADESK
Hei Bud Schroeder
Thank you for yor reply!
I have tried many time and different fil.s , 2d dwg, 3d dwg,and rvt.
alle the fils were uploaded and stay there over an hour. Steel nothing happened.
I don't know what to do.
jay_miller
You mentioned that it was ACA, which tends to create a lot of reference files.  You may need to do a composite upload.  Select the main file first and then all the additional files that need to go with it.  It will them give you the option to do a composite upload and select the main file.  It will then link them correctly when it uploads. See the attached image.
Jay Miller
BHB Consulting Engineers, P.C.
Tags (2)
