I get an error message about cant Upload file.
"Sorry. The operation you requested couldn't be performed."
Is there any person here that get same kind error message?
What is the problem?
thanks for helps.
best wishes.
Ufuk AYDIN
Hi Bud,
I tried Chrome, Firefox, Internet Explorer.
I still get an error message about "cant Upload file". (See attached picture)
No problem file size smaller.
"Autodesk atolye05.pptx"
PPTX file size is 54MB.
thanks
Yes, mail is same.
I did not open any project yet.
As I always do, I only want to upload my files.
Before A360Team, I could upload file that 600MB or more.
Thanks for advance.
Ufuk AYDIN
Sorry for the inconvenience. Team is working on the fix. I will get back to you as soon as possible. Appreciate your patience.
Hi Ufuk-
Sorry for the inconvenience. We are actively working on this issue, in the meantime, a workaround is to upload the file to A360 Drive.
You can access A360 Drive at 360.autodesk.com
Can you try that and let me know if it works?
Thanks for your patience,
Mary
It seems ok. (A360 Drive account)
Thanks.
The file has been upload succesfuly via my "360.autodesk.com" page.
But I think problem is my A360 account below; (see attached picture)
"https://sayisalgrafik.autodesk360.com/portal/folders/?drive=nitrous"
Regards and thanks.
Ufuk
Hi Ufuk
I'm glad the workaround worked for you. Our team is continuing to actively work on this issue, and we will let you know once we have it fixed.
Hi Ufuk-
Would you mind sending me your A360 Drive login credentials so I can try your account? Please send them to first.last@autodesk.com, where my first.last = mary.morse?
I want to see if I can fix your issue.
Hi Ufuk-
Thanks for sending me your login information, I confirmed that your A360 Drive account is working as expected.
I'm happy to report that we have diagnosed the source of your upload failure, and will be working to fix this asap. In the meantime, if you encounter this error again, please use the workaround above and upload your file directly into A360 Drive.
Thanks for your patience!
