A360 Forum
Welcome to Autodesk’s A360 Forums. Share your knowledge, ask questions, and explore popular A360 topics.
Problems completing a project
2 REPLIES 2
atacggu
285 Views, 2 Replies
I have gotten a project started. At some point one of the holes I put in the object got bigger that it was  when I created it and I don't know how to fix that. Also, 2 of my angles aren't the same and the floor is not level and I don't know how to fix that. Next I followed the procedures to insert an SVG file of my logo to place and extrude on the part and then it locks up my program stating that I selected over 6000 faces. I then brought a file in and redrew it by hand and finally got it almost to where I wanted it but cannot bring that into the part project. Very frustrating. So 3 problems and cannot find answers on how to solve. Any help would be appreciated. This is my 2nd attempt at trying to learn fusion 360 and I still don't have even one project workable.
Tim
2 REPLIES 2
carlseoservices
in reply to: atacggu
Exploring AI SEO Services seemed promising at first, but I've encountered several challenges with project completion. While the technology efficiently identifies and targets SEO trends, adapting these findings into our existing workflows has been tough. The integration isn't as seamless as expected, leading to delays and a steep learning curve for our team. It's a powerful tool, but definitely requires a thoughtful approach to fully leverage its capabilities and align it with team skills and project timelines.
flinandy59
@atacggu wrote:
I have gotten a project started. At some point one of the holes I put in the object got bigger that it was  when You can
Tim
You can try using Fusion 360's editing tools to resize the hole accurately. Secondly, you're encountering issues with mismatched angles and an uneven floor, indicating potential design inconsistencies. Double-check your design for errors and use Fusion 360's measurement tools to ensure accuracy. Thirdly, when inserting an SVG file, Fusion 360 becomes unresponsive due to the large number of faces. Consider simplifying the SVG file before importing it or importing it as a sketch instead of directly extruding it. Finally, if you've redrawn a file by hand and want to bring it into your project, import it as a sketch or component and use Fusion 360's editing tools to integrate it as needed. Learning new software like Fusion 360 can be challenging, but with patience and persistence, you'll overcome these obstacles and gain proficiency over time.
Technology Administrators
