I am getting this same error when trying to upload a "Composite" type folder. I went thru the tutorial and selected my main assembly but when I click "Upload" I get the attached screenshot.
Does this error occur for multiple problems?
Did you also select to upload any associated links or parts? It sounds like Inventor, which I have not used much, but I know with AutoCAD and Revit Xrefs or links that you have to upload all the links as well at the same time and then select the Parent File.
Many thanks to all who took a look at this error code for me. Good news, we found our own answer after multiple tries.
The Composite Design does not handle extraneous files very well. If you do a Pack n’ Go, like I did, you may end up with some extra files (like .ipj, .old) that cause hiccups in the upload process. If you select only .ipt and .iam parts it seems to work fine. I hope that helps other folks....Bill
HI Bill,
Thanks for the update on what was causing the problem. Also would you mind sharing the Pack n Go file with me? I would like to share it with the team to see if we can try to fix this in the future. Can you put the zip file in a folder of it's own. Then do a public share of that file andsend me the link. You can send it to my eMAIL addres using my first name "." last name "@" autodesk.com. first.last@autodesk.com. Just swap out first.last@autodesk.com with my actual first and last name.
Thanks again for sharing with us what you found to be the issue. Also when you eMAIL me, let me know what version of Inventor you are using to create the Composit upload.
