A360 Forum
Welcome to Autodesk’s A360 Forums. Share your knowledge, ask questions, and explore popular A360 topics.
Folder permissions on A360 Team
3 REPLIES 3
662 Views, 3 Replies
i have had a lot of questions around A360 Team, one of them being controlling folders down to users.
In Denmark/Norway would 360 Team be able to substitute a project web within the AEC industry, but that requires that we are able to control folders down to user groups or at person level.
Then we could use it for the bidding proces, one folder for download, one for upload, and the rest of the project folders is only availble for the building owner/consultant.
Thank you for your reply
Best regards
Mikkel Vangsgaard
BIM Consultant, AEC/ENI Solutions
Betech Data A/S
3 REPLIES 3
Bud_Schroeder_ADESK
Hi Mikkel,
Thanks for posting your questions about A360. Take a look at
A360 Roles, Permissions and Project Types:
http://forums.autodesk.com/t5/a360-general-discussion/help-a360-roles-permissions-and-project-types/...
I don't believe we are going to allow you the level of control at the folder level that you are asking for. But you could create projects to emulate what you are looking for. Then only invite the people into that project that you want to see what is going on. You would also create that project as a secret project.
Be sure to take a look through our BLOG as well, there is some good information there as well.
A360 Blog:
http://forums.autodesk.com/t5/a360-blog/bg-p/208
Have you created a trial account yet? If not, go to the web site and create the trail and then start out by creating a practice project. Then you can get a better idea how projects and A360 Team work.
http://autodesk360.com
We also have Hangouts on Wednesdays, and this coming Wednesday we will be doing a getting started with A360 Hangout. You can sign up for it at the following link.
http://autodesk360.com/hangout
If you are not able to make the Hangout, be sure to check the links to the previously rerecorded Hangouts
Hope this helps and others may jump in with other suggestions on how to do this as well.
Bud Schroeder
AutoCAD Customer Council Beta Programs
Autodesk Inc.
Autodesk Beta Programs!
in reply to: Bud_Schroeder_ADESK
Hi Bud,
thank you for your quick replies. And I also thought that this might be done by setting up different projects with different permissions. It would in some cases create a lot of projects.
This is for instances how I would see a bidding within the danish AEC area, this is how it usually goes.
Bud_Schroeder_ADESK
Hi Mikkel,
Thanks for the update. Be sure to also check out our IdeaStation, we have a couple posts like what you are asking for. If any of these fit what you are looking for can you add a comment to it and give it kudos. We look at these to help us on what to add and improve in A360 Going forward.
http://forums.autodesk.com/t5/ideas/v2/ideaexchangepage/blog-id/206/tab/most-kudoed
Thanks again for the feedback.
Bud Schroeder
Autodesk Inc.
Technology Administrators
