Sehr geehrte Damen und Herren,
wenn ich eine neue .dwfx Datei hochlade, kann ich diese nicht betrachten.
Ich erhalte immer die Fehlermeldung: "Unable to open DRM / rights-protected file.
Wie kann man das Lösen?
Mit freundlichen Grüßen
Elmar Daubenmaier
Solved by Bud_Schroeder_ADESK. Go to Solution.
Hello and welcome to the forums. I used Google to translate your message.
"Error upload, consider
Dear Sir or Madam,
when I upload a new .dwfx file, I can not see this.
I always get the error message: "Unable to open DRM / rights-protected file.
How can you solving?
Best regards"
It sounds like your DWF file is protected and that is not supported. What you want to do is go back to the product that the DWF was created in, and publish it again with no protection. For example if you disable print, or measure, these all need to be enabled.
Hope this helps and again welcome to the A360 Forums.
