A360 Forum
Welcome to Autodesk’s A360 Forums. Share your knowledge, ask questions, and explore popular A360 topics.
constrain the midpoint of a segment to an axis
3 REPLIES 3
c_alessandrelli
381 Views, 3 Replies
How can you constrain the midpoint of a segment to an axis or a line?
3 REPLIES 3
billugale
in reply to: c_alessandrelli
Two connected construction lines that are equal length between the circles, that will give you the midpoint. Then a horizontal constraint from that to the third circle. https://xender.vip/
First identify the segment by its endpoints 𝐴(𝑥1,𝑦1)A(x1,y1) and 𝐵(𝑥2,𝑦2)B(x2,y2). Calculate the midpoint 𝑀M using the formula 𝑀(𝑥1+𝑥22,𝑦1+𝑦22)M(2x1+x2,2y1+y2). To constrain 𝑀M to the x-axis, set its y-coordinate to zero, giving 𝑀(𝑥1+𝑥22,0)M(2x1+x2,0). To constrain it to the y-axis, set its x-coordinate to zero, giving 𝑀(0,𝑦1+𝑦22)M(0,2y1+y2). For constraining 𝑀M to a line 𝑦=𝑚𝑥+𝑐y=mx+c, ensure 𝑀M satisfies the line equation 𝑦1+𝑦22=𝑚(𝑥1+𝑥22)+𝑐2y1+y2=m(2x1+x2)+c. In CAD software, draw the segment, find the midpoint, and use the constraint tools to lock the midpoint to the desired axis or line. Similarly, in geometric software, you can draw the segment, identify the midpoint, and use tools to constrain the midpoint to the axis or line, ensuring accurate alignment as needed.
rjoynarun
Using construction geometry, create a vertical line from the center of circle one to a point roughly in the middle of the two circles. Now make another construction line from the endpoint of the first line to the center of the second circle. Select both lines and constrain equal. That's your midpoint. Horizontal constraint from that point to the center of the third circle.
Technology Administrators
