Sorry, I could not find the Autodesk Viewer forum on the list.
Is it possible to upload multiple formats individual files to Autodesk Viewer?
I have tried a few times with different files combinations: .rvt, .nwc, .ifc, .nwd, .dwg. without success.
Any tips on how it works and limitations. I guess it cannot federate multiple files but it can open each of them individually or all together if already federated in another software?
Thanks!
Solved by pendean. Go to Solution.
Solved by brett_parkerLUEP7. Go to Solution.
Post moved to A360 as I believe there will be more responses here.
@marcos_camara @brett_parkerLUEP7 the free Online-only VIEWER tool from Autodesk has no support in any forum around here, least of which is this one. Sorry.
In general if you cannot do what you want, it's not available, note the singular word used in the screenshot below, but also notice there is a folder option, not sure if that helps
For Support go here
then
then
then
