Announcement: A360 Drive Ideas was archived on July 24, 2018. You can still share ideas on the A360 Drive Forum.
Confirm first sync (desktop)
Autodesk 360 Sync component (Win system tray) should ask before downloading A360 content to its local cache/folders for the first time for a given user (=creating the user folder). Otherwise you may inadverently copy your personal A360 files to a foreign PC where you login temporarily e.g. to use Live Maps in AutoCAD.
Vladimir Michl,  www.cadstudio.cz  www.cadforum.cz
3 Comments
Thanks for posting your IDEA to the IdeaStation. I just wanted to get some more details about your IDEA.   Are you working in an office where you share computers?   What is the condition where you are seeing file sync on a different computer.
The A360 Desktop Sync is off by default when you are on a new PC, so you would need to enable it before it would start to sync your content.   If you are using someone's eleses system and they have A360 Drive Sync client enabled, you could just pause Sync while logging into A360 on that system. One other option would be to get the data from the WEB Site and not login to your A360 account on a different computer.
So you can disable the Sync Client in advance, but you won't get a warning.  I'm not sure how Sync would know you are not on your system, it's designed to work between comptuers so that might be an intersting challenge.
Let us know more details on this and we can then share it with the team.
Thanks for posting your feedback and I opened this up to comments and kudos as well.
Bud Schroeder
Autodesk Inc.
vladimir_michl
Is the "sync-off" a per-logged-in-user setting? Inadvertent sync shouldn't depend on remembering to first pause something. I'm referring to situations when showing something on collegue's computer, user training, remote assistance, etc.
Status changed to: Under Review
