A360 is a cloud-based workspace that centralizes, connects and organizes your team and project information across your desktop, the web, and mobile devices.
Available in two tiers:
Mobile Access
A360 mobile app for iOS and Android provides access to your A360 hub and projects from your smartphone and tablet devices.
Cloud Storage[1]
Store all project and design data secured to the latest industry standards, certifications and encryption technology.
A360 Free & A360 Team: Project storage that is available for use by the entire project team.
A360 Drive: Folder-based personal cloud storage service
Desktop-to-Cloud Sync
Sync your designs from your desktop to the cloud
Rendering in A360
Fast, high-resolution renderings in the cloud
[1] Maintenance and Desktop Subscription customers are entitled to 25GB.
When you refer to the 25GB cloud storage that you receive when you have Maintenance or desktop Subscription, is this storage on A360 Drive or 'project data' storage?
I have been curious about, whether A360 desktop, can be used as a workspace for Inventor projects, using Vault.
I would like to be able to start work on Inventor at work, go home and continue work on the same file. Or perhaps, continue working on that same file, using Fusion 360.
I know that in Inventor, when you go to the open file dialog box, you can open file from A360. But, how does that come into play, when your working on projects which use the Vault?
I have not been able to find any information on the web, which answers this question.
This question also couldn't be answered by the many technical support people, which I have asked.
It seems, that most technical support people from Autodesk vendors, don't even fully understand how A360 works!
The other question I have is, how do we ensure that no file conflicts develop? Specially if you start working with others, via sharing through A360. Because at the moment, you'd actually have to save duplicate files, into A360. Which voids the purpose of using the Vault.
Is A360, and other related 360 services intended to be used independently of desktop software, such as AutoCAD and Inventor? Or is it meant to seamlessly, allow you to continue work, no matter where are, as I suggested above?
To me, it makes perfect sense that A360 should be incorporated into the Vault or vice versa.
