I've been experience trouble when signing in to A360. Everytime I try to Open the aplication it crashes.
I already tried to reinstall everything but no solutions.
Any ideias on this probelm?
Hello Saulo,
Welcome to the forums and thanks for posting your question. You mention installing, but A360 is WEB based. Can you tell us what application you are opening and maybe share a screen shot of what you are trying to sign into? Then we will have a better idea of what you are seeing and if we need to get you pointed to a different team, or if we can help out here.
Thanks in advance for getting us more details on this and have a great day.
Yes, I just notice that it's actually A360 Desktop.
I use Autocadmap 3d and in order to see Geomaps I need to sign in to this application. As soon as I try to do it, it crashes the whole autocad map system.
Here's a screenshot.
Thanks Saulo for the update, and I moved your message to the A360 Drive forum, although this may still be an install issue. But lets get some more details first to see if we can sort it out.
When you get the error report (CER dialog) do you add your eMAIL address and send it in? If not, can you do that? Then we can ask the team to look up the CER to see what may be causing the crash.
It sounds like you may have a bad install. When you re installed everything, did you also re install the A360 Desktop sync component? You would do this from the same SETUP.EXE that installs the desktop product. It will be one of the component's included with Sync. Also check in the uninstall screen to see what version you have. Last but not least what version is your AutoCAD product and what OS is it installed to?
Thanks for getting us more details on this.
Hi Bud,
I just sent a error report with my email address (error report CER_137275574).
I am using autocad map 2014 and the A360 desktop version is 6.2.10.1700
How can I get the most up to date version?
Thanks for the update, can you tell us what OS you are running on? For example Windows 10 64 bit.
There are no newer downloads above 6.2 for that version of AutoCAD MAP.
One other thing I just thought of. If you right click on the sync icon in the system tray, can you sign in there with out crashing?
Thanks for the details and let me know about the OS version and if you can sign in from the system tray.
I am using Windows 7 64bit.
The sync Icon doesn't even show up on the system tray. It crashes while opening the program.
It was working until 1 or 2 weeks ago. I am not sure, but a colleague suggested that it was after a windows update that it started to crash.
Autocad map is up to date.
I'll be standing by for news.
Thanks.
I did hear back from the team. We have seen an issue like this when the system was running through a proxy server. Do you know if that is the case for your system? If you have an IT group, you may want them to take a look at the following and see if they can reduce the characters to the proxy server and test if that will stop the crash.
Thanks for checking on this and please let us know how this goes.
After some time revolving around the problem with the IT department of the company we finally could resolve the problem.
Here's what they said about the issue:
2 main things were at cause:
What was done:
Thanks.
