Hello. Hopefully I am not missing something obvious. The A360 Drive folder seems to be permanently pinned to my Quick Access list in File Explorer and I cannot get it to unpin. I do not use it and would very much like to remove it from the list but clicking "Unpin from Quick access" doesn't do anything. Any idea what is going on? I'm using Windows 10 and AutoCAD LT 2014 if that helps any..
Hi Devin,
Can you please send me a screenshot of where you see Drive Pinned? (i'm not 100% following this just yet)
If from within A360, then i'm wondering if the below steps will help by just allowing you to turn if off from your settings? This will then only allow you to see all your A360 Projects and not Drive at all, but i'm not sure if this is really what you're asking.
Please let me know,
Thanks for the screenshot Devin,
Let me know,
I do not have A360 Desktop installed. It was originally installed with the AutoCAD LT but was never used so it was uninstalled.
One thing I forgot to mention. I had Windows 8 when everything was originally installed and was upgraded to Windows 10 later. The A360 Desktop was uninstalled after the upgrade. Not sure if that matters though.
Thanks for your help with this. The A360 Drive folder being where it is isn't hurting anything but it's annoying that it's stuck there.
Hi Devin and Brett,
I did some searching and this seems to be a known issue with Microsoft. The problem is that you have uninstalled A360 Desktop Drive, but the shortcut is still there. Give the following steps a try and see if it will remove the shortcut from the "Quick access" menu.
Microsoft Forum Post on this...
"I realize this thread is several months old, but I found a solution in case anyone comes here from google looking for help. Right click the file explorer icon in your dock, click the item you want to get rid of, and in my case it told me it did not exist and asked me to delete it, which I did. Now it's gone!"
One guy reported that this did not work for him, so you may need to create the shotcut link again with a fake folder, then delete it.
Hope this helps and please let us know how this goes.
Bud, thanks for the added input. This is a really odd bug. I can delete the folder itself but for whatever reason WIndows simply will not remove it from the pinned list. Even after deleting the actual folder, it still shows up like it does in the screen shot I posted previously. However, when I click on it, i get this message below. It's like it's there but it's not there. I'm just going to chalk this up as a funky Microsoft bug and hope they fix it at some point. It's not hurting anything, just taking up space on the pinned list.
Hi Devin,
i found another option that that might work. Can you try resetting the quick toolbar and see if that works?
Hope this helps.
I don't know if y'all got this solved or not but I got mine to go away by creating a folder on my desktop named A360 Drive and then just deleting that folder. This instantly removed the quick access pin.
Thanks for the input here Brent, much appreciated.
That worked, thanks Brent. I had tried that before when I first had the issue and it didn't work. There have been a few Windows updates since then so I'm going to assume they fixed whatever was originally causing the issue.
Happy Thanksgiving everyone.
This issue has been plaguing me for months. I created the folder, named it A360 Drive, deleted it and voila! Thank you so much for your help, even if I'm 5 years late.
