Message 1 of 4 (276 Views)
vl-string-subst
276 Views, 3 Replies
01-18-2013 07:37 AM
I have a lisp program that find all texts with xxxx/yyyy pattern in current drawing and save all of them in a TEXT file line by line. (each text in one line).
I want to replace "/" with ",/," when the program writes this Texts to the *.CSV via vl-string-subst function.
So, I add (vl-string-subst ",/," "/" itm) to this lisp program.
But it doesn't work and makes an error.
Can anybody help me?
(defun c:W2csv (/ strs fname file i)
(if (and (= (getvar 'DwgTitled) 1)
(setq strs nil
ss (ssget (list '(0 . "TEXT") (cons 1 "*/*"))))
(setq fname (strcat (getvar "dwgprefix") (vl-filename-base (getvar "dwgname")) ".csv"))
(setq file (open fname "w"))
(progn
(repeat (setq i (sslength ss))
(setq strs (cons (cdr (assoc 1 (entget (ssname ss (setq i (1- i)))))) strs))
(foreach itm (vl-sort strs '<))
(write-line (vl-string-subst ",/," "/" itm) file)
(close file)
(startapp "Notepad" fname)
(princ)
Message 2 of 4 (270 Views)
Re: vl-string-subst
01-18-2013 07:54 AM in reply to: aqdam1978
You prematurely close the foreach line here
(foreach itm (vl-sort strs '<));<----
Message 3 of 4 (258 Views)
Re: vl-string-subst
01-18-2013 09:29 AM in reply to: pbejse
Thank you so much.
Message 4 of 4 (232 Views)
Re: vl-string-subst
01-19-2013 07:00 AM in reply to: aqdam1978
aqdam1978 wrote:
Thank you so much.
You are welcome.
I'm happy to help. :smileyhappy:
You are not logged in.
Ask the Community
