hi all
i have in Drive C a file "Steel.lsp" have function called IPE
in this function have this line
(setq n (getstring "\nEnter IPE Height :"))
i loaded it
i created a menu and command in it called "Amr"
no i need when i click Amr Run IPE with string 270 then click enter
i need all this happen automaticlly when i click on "Amr" on menu
how???
amremad_world,
if I understand correctly, and you only want IPE's 270...
replace
by
(setq n "270")
hope that helps
Henrique
[AMR]^C^CAMR 270
this tool button macro invoked 'AMR' command and does not pauses
is this what you had in mind?
moshe
