layer state delete
12 REPLIES 12
Message 1 of 13
Hidden_Brain
1245 Views, 12 Replies
layer state delete
i have a small lisp and i would like for it to:
  1. when i invoke the plot command, it will first check if there is a layer state called "Temp"
  2. if "Temp" exists, then delete "Temp", then re-create "Temp", then switch layer state temporariliy to "Plot" to plot the file, and then switch back to the "Temp" layer state again
  3. basically, the "Plot" layer state will be set based on how the drawing(s) will plot. if a user makes changes here-n-there in the drawing, when the user wants to plot, the software will save current state as "Temp", plot using the "Plot" state, and switch back to "Temp" state at the end. all i am trying to achieve is to somehow over-write the "Temp" state. below is the LISP, any help is appreciated.
(command "undefine" "plot")
(defun c:plot ()
(if (layerstate-has "Temp")
(layerstate-delete “Temp”)
(command "Layer" "A" "S" "Temp" "" "" "")
(command "Layer" "A" "R" "plot" "" "" "")
(command ".plot" "Yes" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "")
(command "Layer" "A" "R" "Temp" "" "" "")
(graphscr)
(princ)
12 REPLIES 12
Message 2 of 13
Hidden_Brain
in reply to: Hidden_Brain
sorry for the "accidental" smiley, it should be
(defun c "colon sign" plot ()
Message 3 of 13
Jeff_M
If you use the Code tags you don't get the smiley's 🙂
(defun c:plot ()
(graphscr)
(princ)
Message 4 of 13
Hidden_Brain
in reply to: Jeff_M
thanks for the tip Jeff. any suggestions on how to make the code run?
Message 5 of 13
Jeff_M
I was working on that...this will delete the TEMP Layerstate if it exists:
(vl-load-com)
(setq lays (vla-get-layers (vla-get-activedocument (vlax-get-acad-object))))
(if (vla-get-hasextensiondictionary lays :vlax-true)
  (progn
    (setq exdict (vla-getextensiondictionary lays))
    (setq dict (vla-item exdict "ACAD_LAYERSTATES"))
    (vlax-for xrec dict
      (if (eq (strcase (vla-get-name xrec)) "TEMP")
	(vla-delete xrec)
Message 6 of 13
hmsilva
youngPE,
perhaps something like
(defun c:plot ()
(layerstate-delete "Temp")
(command "-Layer" "A" "S" "Temp" "" "" "");; changed to commandline version
(command "-Layer" "A" "R" "plot" "" "" "");; changed to commandline version
(command "-plot" "Yes" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "");; changed to commandline version
(command "-Layer" "A" "R" "Temp" "" "" "");; changed to commandline version
(graphscr)
(princ)
should work well, I do not know if the number of enters in the plot command is correct or not, you have to test it.
Henrique
Message 7 of 13
Hidden_Brain
in reply to: Jeff_M
Jeff,
i merged what you gave with what i had (added two extra parantheses at the end of yours), loads fine, but gives me an error as:
Command: plot
; error: Too many actual parameters
i must be doing something dumb here, but cannot figure out what. do you have any ideas? merged code is below:
(defun c:plot ()
(vl-load-com)
  (progn
    (vlax-for xrec dict
    (vla-delete xrec)
(graphscr)
(princ)
Message 8 of 13
Hidden_Brain
in reply to: hmsilva
Henrique,
yours seem to work very well! i didnt expect that going to the command line version would make the difference, thanks!
Message 9 of 13
hmsilva
youngPE,
in my previous post, I forgot to redefine the plot command,
You should receive an error such as;
Command: PLOT Unknown command "PLOT".  Press F1 for help.
(defun c:plot ()
(command "_redefine" "plot");; restores the plot command
(graphscr)
(princ)
 Henrique
Message 10 of 13
Kent1Cooper
[Another way to avoid smileys:  see the instructions at the top of this thread.  But when you know you're using a colon-and-letter combination that triggers some smiley [see the list there], using a code window will prevent the smiley for others who aren't signed in, or for those who are but who don't have them turned off.  (There was a time when even a code window didn't prevent it, but that's no longer a problem.)]
Kent Cooper, AIA
Message 11 of 13
Jeff_M
Well, that'll teach me to visit the lisp forum once every few years...I didn't know that the layerstate-* functions existed.....I thought you were looking for a way to do what they do.... Smiley Embarassed
Message 12 of 13
Hidden_Brain
in reply to: Jeff_M
no worries Jeff, I have personally always learned something new from you every time you have replied to my questions. thanks again for sharing all the knowledge!
Message 13 of 13
Hidden_Brain
thanks again everyone for helping me out with this one!
”Boost
