Visual LISP, AutoLISP and General Customization
One is NIL - One is T
10 REPLIES 10
Message 1 of 11
362 Views, 10 Replies
I have one variable that is T and the other is NIL,
how to assign the one that is T to a variable.
sample...
(setq PC_Name (getenv "computername"))
(setq User_Name (getenv "username"))
(setq ChkUserName (dos_dirp (strcat "I:\\" User_Name)))     ; is T
(setq ChkPCName (dos_dirp (strcat "I:\\" PC_name)))           ; is NIL
(setq THEONETRUE (......)) ;;; HOW TO ASSIGN THE ONE TRUE
Thank you in advance for your help.
DC
10 REPLIES 10
Message 2 of 11
rkmcswain
So you have two variables, one of which will always be nil and the other will always contain a non-nil value?
(setq a nil b "value")
(if a (setq thetrueone a)(setq thetrueone b))
Message 3 of 11
in reply to: rkmcswain
thanks, but this way only THETRUEONE return "T" it does take the "value".
Message 4 of 11
my mistake.... you right. thank you.
Message 5 of 11
Kent1Cooper
sample...
In that situation, I hope I'm correct in assuming that what you want to set into the THEONETRUE variable is the value in either PC_Name or User_Name [whichever is the True one], and not the result of ChkUserName or ChkPCName.  If so, try:
(setq THEONETRUE (cond (ChkUserName User_Name) (ChkPCName PC_Name)))
Kent Cooper, AIA
Message 6 of 11
hgasty1001
I can't made much sense of your request, as if it's for the value of the var THEONETRUE, you will always end up with T as the value, maybe this is what you need:
(setq THEONETRUE (if ChkUserName "ChkUserName" "ChkPCName"))
Gaston Nunez
Message 7 of 11
Kent1Cooper
Or, in that situation [which I don't think is exactly what the OP is trying to do]:
(setq thetrueone (cond (a) (b)))
Kent Cooper, AIA
Message 8 of 11
Gary_J_Orr
you need to expand R.K.'s response for your situation:
given your statments:
sample...
(setq THEONETRUE (......)) ;;; HOW TO ASSIGN THE ONE TRUE"
 and R.K.'s response:
(if ChkUserName (setq THEONETRUE User_Name) (setq THEONETRUE PC_Name))
or you could roll over to a cond stmt to be able to set the first "T" value to the variable and have a failsafe in case neither is true that will set "THEONETRUE" to nil
(setq THEONETRUE (cond ((= T ChkUserName) User_Name) ((= T ChkPCName) PC_Name) (T nil) ))
-Gary
Gary J. Orr
(Your Friendly Neighborhood) CADD/BIM/VDC Applications Manager
http://www.linkedin.com/in/garyorr
aka (current and past user names):
Gary_J_Orr (GOMO Stuff 2008-Present); OrrG (Forum Studio 2005-2008); Gary J. Orr (LHB Inc 2002-2005); Orr, Gary J. (Gossen Livingston 1997-2002)
Message 9 of 11
Kent1Cooper
in reply to: Gary_J_Orr
That's exactly what my first reply does with less code.  There's no need to check whether (= T ChkUserName), when the mere fact that ChkUserName is not nil is enough.  And there's no need to explicitly set it to nil if none of the conditions is True -- that will happen without spelling out a fallback condition, because the (cond) function will return nil if it gets to the last condition and none has been satisfied.
Kent Cooper, AIA
Message 10 of 11
Kent1Cooper
in reply to: Kent1Cooper
.... try:
If you don't otherwise have any need for the variables ChkUserName and ChkPCName, but are using them only as intermediaries to find whether there are directories related to those Environment Variables, you can eliminate the middlepeople and do it a little more directly:
(setq THEONETRUE
  (cond
    ((dos_dirp (strcat "I:\\" User_Name)) User_Name)
    ((dos_dirp (strcat "I:\\" PC_name)) PC_Name)
Kent Cooper, AIA
Message 11 of 11
Gary_J_Orr
yeah Kent...it's exactly what you posted (I was writing my response while you posted that one I believe since I had not seen yours yet)...
and true, you don't need the (= T...) but it may help the OP understand how it works.
Gary J. Orr
”Boost
