Hi everyone,
at my new workplace I'm supposed to use a vast company-specific block library.
For some reason the block were saved (back in 1999) without name, only numbers.
So I have to literally go through all the blocks to find oout what is what.
I don't know much about LISP but enough to know that there is a way to have autocad do this;
This way i get a preview.
Much obliged
Manu
Try a Search. I put "Drawing Preview" in the Search window and got a lot of hits, some of which look like pretty much the same question [though I didn't dig into all of them].
Have you considered using the DWG Convert function in TrueView?
Ok, I see that you've already recieved an example, but since I told you that I was doing it, here goes another approach.
(DEFUN C:POB (/ DIR DIRF) (SETQ DIR "C:/DWG/FILES/DIRECTORY/" DIRF (VL-DIRECTORY-FILES DIR "*.DWG" 1) ) (FOREACH IDX DIRF (IF (VLA-ACTIVATE (VLA-OPEN (VLA-GET-DOCUMENTS (VLAX-GET-ACAD-OBJECT)) (STRCAT DIR IDX) :VLAX-FALSE)) (AND (VL-CMDF "-PURGE" "A" "*" "N") (VL-CMDF "ZOOM" "E" PAUSE) ) ) ) )
I understand why you got all the suggestions for scripts, but my version will simply pause for you to save or close the current active drawing.
Just copy your drawings to C:\THUMB
load this lisp and type UTB for running!
;; drawing purger for thumbnail update purpose ;; By Abbas Aqdam (defun C:UTB ( / path files dwg sf ) (if (or (= (getvar "SDI") 0) (> (getvar "DBMOD") 0)) (alert "Please: \n\n1-SAVE and close all open drawing!\n\n2-Set SDI to 0") (progn (setq path "C:\\THUMB\\") (setq files (vl-directory-files path "*.dwg" 1)) (if (> (length files) 0) (progn (setq sf (open (strcat path "T.SCR") "w")) (write-line "Filedia" sf) (write-line "0" sf) (foreach dwg files (write-line "open" sf) (write-line (strcat "\"" path dwg "\"") sf) (write-line "(command \"purge\" \"a\" \"*\" \"N\")" sf) (write-line "(command \"zoom\" \"e\" \"zoom\" \"s\" \"0.95x\")" sf) (write-line "qsave" sf) );foreach (write-line "Filedia" sf) (write-line "1" sf) (close sf) (command "script" (strcat path "t.scr")) );progn (Alert (strcat "There is no dwg files in " path "!")) );if );progn );if );defun
Abbas
Wow, there are several paths to follow here.
I'm going to try all 'till I find what works best.
Thanks a bunch guys, you're the best!
