Visual LISP, AutoLISP and General Customization
*Nienberg, Mark
Message 1 of 10 (425 Views)
GLUE lisp routine
425 Views, 9 Replies
11-13-2000 04:20 PM
There was a lisp routine named GLUE.lsp that came with SoftDesk 8 that we
used to use all the time. In fact, the routine is still installed as part
of the "Details" install under Architectural Desktop 2. Unfortunately, it
doesn't work anymore. It goes into an endless initialization loop when
started.
Is there an alternative to this or a way to fix it? We use it primarily to
convert multiple line segments into a single line, but it used to work with
text, arcs, etc. Thanks,
Mark Nienberg
*Tovar, Rudy
Message 2 of 10 (425 Views)
Re: GLUE lisp routine
11-13-2000 04:46 PM in reply to: *Nienberg, Mark
I believe that was a clean up lines utility.
I don't have it but you could wait for another reply.
rudy@cadentity.com
Practical Utilities for Productive Solutions
Mark Nienberg wrote in message
news:smileyvery-happy:2CF06ACE8C45D9EC65E534BB3DB3AE0@in.WebX.SaUCah8kaAW...
> started.
to
with
> Mark Nienberg
*Chico_Don
Message 3 of 10 (425 Views)
11-13-2000 06:27 PM in reply to: *Nienberg, Mark
What does it do?
Don
"Mark Nienberg" wrote in message
> started.
to
with
> Mark Nienberg
*IBM
Message 4 of 10 (425 Views)
11-13-2000 06:53 PM in reply to: *Nienberg, Mark
is this is what you are talking about (old as dirt)
;GLUE.LSP
;Draws a single line between the two most-distant points of two
;user-selected lines. Erases the two user-selected lines. Assigns
;to the new line the same properties of Layer, Color, Linetype, and
;Thickness as those of the first user-selected line.
;For AutoCAD Release 10
;Written 02/19/1989 Brad Zehring Autodesk, Inc. Training Department
(defun C:GLUE (/ l1 l2 e1 e2 dl ml temp p pt1 pt2
old_flatland old_cmdecho)
(setq old_flatland (getvar "flatland"))
(setq old_cmdecho (getvar "cmdecho"))
(setvar "flatland" 0)
(setvar "cmdecho" 0)
(setq l1 (entsel "\nSelect first line: "))
(if l1 (redraw (car l1) 3))
(setq l2 (entsel "\nSelect second line: "))
(if l2 (redraw (car l2) 3))
(if
(or (eq l1 nil) (eq l2 nil))
(prompt "\nRequires two lines. *Invalid*")
(progn
(if
(not
(and
(eq "LINE" (cdr (assoc 0 (setq e1 (entget (car l1))))))
(eq "LINE" (cdr (assoc 0 (setq e2 (entget (car l2))))))
(progn
(setq dl nil)
(setq dl
(cons
(list (distance (cdr (assoc 10 e1)) (cdr (assoc 10 e2))) 11)
dl
(setq dl
(cons
(list (distance (cdr (assoc 10 e1)) (cdr (assoc 11 e2))) 12)
dl
(setq dl
(cons
(list (distance (cdr (assoc 11 e1)) (cdr (assoc 10 e2))) 21)
dl
(setq dl
(cons
(list (distance (cdr (assoc 11 e1)) (cdr (assoc 11 e2))) 22)
dl
(setq ml nil temp dl)
(repeat 4
(setq ml (cons (car (car temp)) ml))
(setq temp (cdr temp))
(setq p (car (cdr (assoc (eval (cons 'MAX ml)) dl))))
(cond
((= p 11)
(setq pt1 (cdr (assoc 10 e1)))
(setq pt2 (cdr (assoc 10 e2)))
((= p 12)
(setq pt2 (cdr (assoc 11 e2)))
((= p 21)
(setq pt1 (cdr (assoc 11 e1)))
((= p 22)
(t)
(command ".line" pt1 pt2 "")
(command ".chprop" (entlast) ""
"LA" (cdr (assoc 8 e1))
"C" (if
(null (cdr (assoc 62 e1)))
(cdr (assoc 62 e1))
"LT" (if
(null (cdr (assoc 6 e1)))
(cdr (assoc 6 e1))
"T" (if
(null (cdr (assoc 39 e1)))
(cdr (assoc 39 e1))
(command ".erase" l1 l2 "")
(redraw (entlast) 1)
(setvar "flatland" old_flatland)
(setvar "cmdecho" old_cmdecho)
(prin1)
> started.
to
with
> Mark Nienberg
*Ng, Peter
Message 5 of 10 (425 Views)
11-13-2000 08:52 PM in reply to: *Nienberg, Mark
Mark,
Attached is a lisp to 'glue' text together. It doesnt do all in one as your
old one, but might help you out.
Peter
> started.
to
with
> Mark Nienberg
*Harper, Chip
Message 6 of 10 (425 Views)
11-14-2000 04:13 AM in reply to: *Nienberg, Mark
Is this what you are looking for?
; This routine joins two lines, two arcs, two 3dfaces, or two text items
; together. If arcs are selected, they must share a common center point and
radius.
; For lines there is no such restriction. Two lines of different angles can
be
; joined. The program loops to allow several pairs of objects to be joined.
; When gluing text together, the text value of the second selected text
; item is added on to the first. A space is inserted between text items.
Posted to Customer Files
> started.
to
with
> Mark Nienberg
*Nienberg, Mark
Message 7 of 10 (425 Views)
Re:
11-15-2000 05:51 PM in reply to: *Nienberg, Mark
Thats it! Thanks.
Mark Nienberg
"Chip Harper" wrote in message
news:B935D869FE791EFF9A62C498C00BEAA9@in.WebX.SaUCah8kaAW...
and
> radius.
can
> be
joined.
we
part
it
> > started.
> to
> with
> > Mark Nienberg
New Member
Message 8 of 10 (315 Views)
01-21-2013 09:14 AM in reply to: *Nienberg, Mark
Gentlemen;
I’m an old timer (dinosaur) whom used the glue lisp routine.
presently I use AutoCAD lt 2002
I have been reading this blog specifically to try and understand how I may "download" or copy/ paste this routine into my lt 2002 program?
Have you any suggestions?
Thank you in advance.
don
Distinguished Contributor
Message 9 of 10 (292 Views)
01-21-2013 12:32 PM in reply to: *Nienberg, Mark
try OVERKILL... it does more
*Expert Elite*
M_Hensley
Message 10 of 10 (273 Views)
01-22-2013 04:06 AM in reply to: dondavisjr
Unfortunately LT does not allow you to use lisp programs.
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
