Export text to excel for a batch of dwg files
5 REPLIES 5
shravan.troy
2216 Views, 5 Replies
I am looking for a autoLISP that will export text from autocad drawing batch (say 25 drawings) to excel in the following format.
I need rows with drg file name, text and the layer (in which the text is as shown) - below sample rows
Can some one please help me with this one ?
Drg file name    text from autocad        layer
ARCH1001        TYPICAL                      TEXT
ARCH1001        Window11                 Window_schedule
ARCH1002        CUT BACK                   TEXT
ARCH1002        Window21                 Window_schedule
ARCH1003          6                                WELD
ARCH1003        Window31                 Window_schedule
ARCH1003        Window32                  Window_schedule
ARCH1003        Window33                  Window_schedule
ARCH1003        Window34                  Window_schedule
5 REPLIES 5
Welcome to Autodesk forum.
You can do this DATAEXTRACTION (DX) command
shravan.troy
in reply to: shravan.troy
From which version of autocad this dataextraction command works ?
I dont know from which version of autocad it started.
But should work from 2008 series.
Also I am not sure whether this command exists in LT (If you are using LT)
Which version you have ?
It works, thanks a lot
You're welcome
Glad I could help.
”Boost
