Can you change the color of a block attribute with lisp like you can with the built in Enhanced Attribute Editor function eg
I can change the value of the attribute LAMP but can I also change its color from the color of the layer its created on?
(while (not (equal ck "SEQEND"))
(setq e1 (entnext e1)
e2 (entget e1)
ck (cdr (assoc 0 e2)))
(if (= (cdr (assoc 2 e2)) "LAMP")
(progn
(setq e2 (subst (cons 1 lamp)(assoc 1 e2)e2))
(entmod e2)
(entupd e1)
(setq ctr (+ ctr 1))
rodb,
perhaps something like
(setq e2 (subst (cons 1 lamp) (assoc 1 e2) e2)) (if (assoc 62 e2) (setq e2 (subst (cons 62 2) (assoc 62 e2) e2));; color 2 (setq e2 (append e2 (list (cons 62 2))));; color 2 ) (entmod e2)
hope that helps
Henrique
It is working! Now I just have to polish the routine to ask for a color as well as a lamp type with a drop down menu which I have done before some time ago. Thanks!
@Anonymous wrote:Can you change the color of a block attribute with lisp like you can with the built in Enhanced Attribute Editor function eg
Not sure what you mean by "created on" , is that block layer or the ATTDEF layer?
if its the former
(defun demo (str tag / ss y) (vl-load-com) (if (setq ss (ssget ":L" '((0 . "INSERT") (66 . 1)))) (repeat (sslength ss) (if (setq y (vl-some '(lambda (x) (if (eq (vla-get-tagstring x) tag) x)) (vlax-invoke (vlax-ename->vla-object (ssname ss 0)) 'Getattributes))) (mapcar '(lambda (j k) (vlax-put y J k)) '("Textstring" "Color") (list str (cdr (assoc 62 (tblsearch "Layer" (vla-get-layer y))))))) (ssdel (ssname ss 0) ss))) (princ) )
(demo "New String" "LAMP")
HTH
EDIT: to add a color option
(defun demo2 (str tag col / ss y) (vl-load-com) (if (setq ss (ssget ":L" '((0 . "INSERT") (66 . 1)))) (repeat (sslength ss) (if (setq y (vl-some '(lambda (x) (if (eq (vla-get-tagstring x) tag) x)) (vlax-invoke (vlax-ename->vla-object (ssname ss 0)) 'Getattributes))) (mapcar '(lambda (j k) (vlax-put y J k)) '("Textstring" "Color") (list str col))) (ssdel (ssname ss 0) ss))) (princ) )
(demo2 "New String" "LAMP" 2)
or even
(Defun c:demo3 ( / str tag col ss y) (if (and (setq str (getstring T "\nEnter New String:")) (not (eq "" str)) (setq tag (strcase (getstring "\nEnter Tag to search:"))) (not (eq "" tag)) (setq col (setq lst (acad_colordlg 7 nil))) (setq ss (ssget ":L" '((0 . "INSERT") (66 . 1)))) ) (repeat (sslength ss) (if (setq y (vl-some '(lambda (x) (if (eq (vla-get-tagstring x) tag) x)) (vlax-invoke (vlax-ename->vla-object (ssname ss 0)) 'Getattributes))) (mapcar '(lambda (j k) (vlax-put y J k)) '("Textstring" "Color") (list str col))) (ssdel (ssname ss 0) ss)) ) (princ) )
command: Demo3
Enter New String:hahaha
Enter Tag to search:LAMP
<Color dialog>
Select objects:
HTH
Thank you everyone. The program is working perfectly now. I was wanting to change the color of the attribute tag which is on a cyan layer by default not the color of the block layer. Using Henrique's option it works well. This is the program snippet now. I'm sure there are better ways of writing it but my Lisp is not that good.
(setvar "DYNMODE" 3)
(if (equal kelvin nil)
(setq kelvin 4))
(initget 7 "2800k 3000k 32000k 34000k 4000k 5000k")
(setq ctemp (getkword "\n Choose Colour Temperature [2800k/3000k/32000k/34000k/4000k/5000k] :"))
(setq kelvin (cond((= ctemp "2800k") 6)
((= ctemp "3000k") 1)
((= ctemp "32000k") 26)
((= ctemp "34000k") 3)
((= ctemp "4000k") 4)
((= ctemp "5000k") 5)
(prompt "\nPick your Blocks..")
(setq ss (ssget '((0 . "insert")))
sl (sslength ss)
ct 0
ctr 0)
(repeat sl
(setq e1 (ssname ss ct))
(setq ck 2)
e2 (entget e1)
(progn
(setq e2 (subst (cons 1 lmp)(assoc 1 e2)e2))
(if (assoc 62 e2)
(setq e2 (subst (cons 62 kelvin) (assoc 62 e2) e2))
(setq e2 (append e2 (list (cons 62 kelvin))))
(entmod e2)
(entupd e1)
Hate to burst your bubble but "Battman" command works well for this.
But it does not allow you to select multiple blocks and the danger is it will assign a particular lamp to all those blocks, also the lisp is faster and much easier to use, it remembers your lamp and colour allowing you to pick and choose which blocks to edit. I have tried many times to get people in the office to use the built in AutoCAD commands like attedit but they simply forget how to use them and find them too long winded when they do remember them. Much better a Lisp with a clear menu pick option that you can find easily and asks direct questions then completes the task efficiently and remembers your choices.
rodb,
for setting the color temperature of the lamps, you ask the user to write the complete definition of the lamp
eg 32000k, six digits, facilitating the error by forcing the user to provide as high a number of digits,
might be more user friendly allow the user to provide only a few digits,perhaps something like
(initget 7 "2800k,28 3000k,30 32000k,32 34000k,34 4000k,40 5000k,50") (setq ctemp (getkword "\n Choose Colour Temperature [(28)2800k/(30)3000k/(32)32000k/(34)34000k/(40)4000k/(50)5000k] :"))
this way allows the user, if choose the lamp of 32000k, just enter 32, making it easier to choose the lamp...
hope that helps
Henrique
Thank you Henrique, thats a good idea, at the moment though the program allows the user to click on an on screen menu so all he has to do is fill in the lamp type using the keyboard and then click on the required color temperature, no typing required for the color temp selection. But sometimes people have set their computer to disable the on screen menu or they keep their mouse off the graphic screen area and don't see the menu so they would then have to type it in so I will make a short cut type in option like you suggest as well.
You're welcome,rodb
the menu is a good solution, to prevent that someone disable the on screen menu, You may also consider using a DCL ...
Henrique
Hmmm I have never used DCL but it could be very useful for me so I will definately look into it - thanks again!
Sorry rob, my battman comment was in response to your original question: Can you change the color of a block attribute with lisp...
I see now there was more to it.
