Valued Contributor
Message 1 of 5 (644 Views)
Change Dynamic Block Property "Scale Uniformly" Automatically
644 Views, 4 Replies
12-16-2010 09:01 PM
G'day,
Been trying to figure out how to change the Scale Uniformly property in dynamic blocks accross hundreds of drawings using either/or scripts, lisp, vba or anything else that might do the job.
WIth my limited knowledge of programming im wondering if there is someone out there that may be able to help me out?
just need to open the drawing and select the block (one block per drawing) then edit the scale uniformly property within the block, save then close the drawing and move onto the next drawing.
Thank you in advance for your help with this matter.
Jason
Distinguished Mentor
Message 2 of 5 (631 Views)
Re: Change Dynamic Block Property "Scale Uniformly" Automatically
12-17-2010 12:11 AM in reply to: jason.estas
see if this helps... no error control
(setq obj (vlax-ename->vla-object (car (entsel)))
      blknm (vlax-get obj 'Effectivename)
(vlax-for blk (vla-get-blocks
                (vla-get-ActiveDocument
                  (vlax-get-acad-object)))
  (if (eq blknm (vla-get-Name blk))
    (vlax-put blk 'BlockScaling acUniform))
~~~Civil 3D 2008~~~
Distinguished Contributor
msarqui
Message 3 of 5 (214 Views)
02-06-2013 04:24 PM in reply to: lpseifert
Sorry for the question but: How I use it?
I tred this but I get an error when autocad starts...
(Defund c:BUS ()
Message 4 of 5 (208 Views)
02-06-2013 06:43 PM in reply to: msarqui
(Defund c:BUS ()
(Defun c:BUS ()
msarqui
Message 5 of 5 (191 Views)
02-07-2013 10:14 AM in reply to: pbejse
hahaha. I guess I was tired...
Now it works fine but only one block at a time. I mean, it does not change automaticaly nested blocks. Also it does not accept "select all". I think I'll try to find another one :smileysad:
Thanks pbejse!
You are not logged in.
Ask the Community
