G'day,
Been trying to figure out how to change the Scale Uniformly property in dynamic blocks accross hundreds of drawings using either/or scripts, lisp, vba or anything else that might do the job.
WIth my limited knowledge of programming im wondering if there is someone out there that may be able to help me out?
just need to open the drawing and select the block (one block per drawing) then edit the scale uniformly property within the block, save then close the drawing and move onto the next drawing.
Thank you in advance for your help with this matter.
Jason
Solved by lpseifert. Go to Solution.
see if this helps... no error control
(setq obj (vlax-ename->vla-object (car (entsel))) blknm (vlax-get obj 'Effectivename) ) (vlax-for blk (vla-get-blocks (vla-get-ActiveDocument (vlax-get-acad-object))) (if (eq blknm (vla-get-Name blk)) (vlax-put blk 'BlockScaling acUniform)) )
Sorry for the question but: How I use it?
I tred this but I get an error when autocad starts...
(Defund c:BUS ()
