Attribute or field
7 REPLIES 7
Message 1 of 8
496 Views, 7 Replies
Attribute or field
Is it possible to make an attribute or a field in a template with page numbering for layouts?
Is it possible to make an attribute or a field in a template with the name of the layout?
Louis
7 REPLIES 7
Message 2 of 8
Alfred.NESWADBA
IMHO not without development, because AutoCAD has no property "page number".
you can show the current layout when using CTAB sysvar to be shown.
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
Message 3 of 8
pbejse
in reply to: Alfred.NESWADBA
- alfred -
Watch out for multiple layout tabs when using fields.
Message 4 of 8
Alfred.NESWADBA
in reply to: pbejse
When you create a field (showign CTAB) in each layout and you activate this layout (or you plot it) the field always shows the correct value.
Or do I understand anything wrong? What do you mean by that "watch out"?
- alfred -
Alfred NESWADBA
Message 5 of 8
pbejse
- alfred -
Yes you are correct. I should've said when using publish command.
Most companies i know tends to use publish especially with multiple layout tabs and it always messed up the sheet numbers when using field values.
Message 6 of 8
Alfred.NESWADBA
in reply to: pbejse
I just have it tried (only to be more than sure):
  • Started AutoCAD 2013 SP1.1 German x64
  • goto Layout 1
  • created a text containing a field with the content of CTAB
  • goto Layout 2
  • copied the layout twice
  • marked the layouts "Layout 1" to "Layout 2 (3)"
  • started command _PUBLISH, set to PDF (not using background plot)
  • ...and find the result attached 😉
But you are right, in previous AutoCAD releases that fields were not updated when plotting. So to be careful and verify that fields after plotting is necessary.
- alfred -
Alfred NESWADBA
Message 7 of 8
pbejse
- alfred -
I see, Good to know its not going to be a problem in newer versions of Autocad .
Cheers
Message 8 of 8
Thank you all
Cat Very Happy
”Boost
