Visual Basic Customization
*Allaire, Yves
Message 1 of 3 (75 Views)
Object variable not set
75 Views, 2 Replies
12-18-2000 03:19 AM
Why this code gives me object variable not set, I use it inside Excel,
and AutoCAD R 14.01 is running...
Dim acadObj As AcadApplication, points(0 To 2) As Double, mspace As
AcadModelSpace
Dim apoint As AcadPoint, test, cadDoc As AcadDocument
Dim nombrow As Integer, x As Integer
Set cadDoc = acadObj.ActiveDocument
*jwk
Message 2 of 3 (75 Views)
Re: Object variable not set
12-18-2000 03:41 AM in reply to: *Allaire, Yves
You need one more thing, like
set AcadObj=GetObject(AutoCAD.Application)
wkr, jwk
You ask a silly question, you get a technical answer...
Yves Allaire had the next bright idea:
>Thanks
>AcadModelSpace
*Allaire, Yves
Message 3 of 3 (75 Views)
Re:
12-18-2000 05:05 AM in reply to: *Allaire, Yves
Thanks, it works!!!
There is no way to bound at the Dim line, I though I heard this somewhere?
Thanks.
> wkr, jwk
> >Thanks
> >AcadModelSpace
You are not logged in.
Ask the Community
