0 Kudos
Carl_mgfx
Copy Design, Replace first "x" amount of text
Status: Comments Requested
by Valued Contributor Carl_mgfx on ‎05-13-2013 04:35 AM
Hi all
I have seem many request for better file renaming within "Copy Design", this request is to add the renaming functionality.
It would be good to be able to replace a selected string length, within a name, with a new set of text.
My example is as follows:  The first 5 characters of my file name are a code linked to the specific internal project number for the design.  If I want to copy designs from various internal projects for reuse in a new project I need to replace the first 5 characters with a new text.
eg.
Project 1 code = 12345
Parts:
12345-abcd
12345-efghi
12345-jklmn
Project 2 code = xx12x
Parts:
xx12x-12345
xx12x-67891
If I run a rename of just the first 5 characters I can rename all the parts at once to have a new project number, instead of having to do a replace all for each project code copied from.
What would be nice is to be able to specify a seperator (in this case "-") and replace all text before it.
Use of wildcards would also help.
Comments
by Board Manager ihayesjr on ‎09-13-2013 12:24 PM
Status changed to: Comments Requested
You are not logged in.
IdeaStation Guidelines
Review guidelines and best practices
before posting a new idea
Top Kudoed Authors
User Kudos Count
12
9
7
5
5
