I've confirmed that the content library installer does, in fact, always
use the standard "Program Files" location when installing the library
data files.
If you want to move these into the normal data area, you should first
detach the libraries using the Content Center Library Manager, then move
the data files into the other place, then re-attach them.
Jeff
MikeMc wrote:
> Jeff,
> I believe the attached pictures will help show my current installation.
> Thanks, Mike
> "Jeff Pek (Autodesk)" wrote in message
> news:4951394@discussion.autodesk.com...
> When you say the content manager, are you referring to the Inventor
> standard content data? What file(s) do you see in that directory?
> Thanks,
> Jeff
> MikeMc wrote:
>>Thanks for the help.
>>I did set the default data file location to 😧 drive during the SQL
>>installation. However, the Co
> ntent Manager installer must be hard coded to
>>the C:\Program Files\Microsoft SQL Server\MSSQL$AUTODESKVAULT\Data
>>location.
>>MikeMc
>>news:4951251@discussion.autodesk.com...
>>It's possible to control the installation of SQL server to have it keep
>>its data files in a place other than C: -- however, I don't recall that
>>the usual installation UI provides an opportunity to do this.
>>You can use the DetachLibr
> ary utility (content folder) to detach the
>>content library databases, move them to where you want, and then use the
>>AttachLibrary tool to reconnect them.
>>We recommend that all data files be kept together for reliability of
>>maintenance tasks.
>>Jeff
>>MikeMc wrote:
>>>Installation of the Vault went OK. I installed SQL Data files to the 😧
>>>drive.
>>>The Content Manager, however, put it's data files under C:\Program
>>>Files\Microsoft SQL Server\MSSQL$AUTODESKVAULT\Data. I wa
> s hoping to
>>>install
>>>ALL data files to the 😧 drive. The C: partition was 'imaged' before I
>>>installed the Vault and Content Manager. I can start over or perhaps you
>>>another suggestion.
>>>Thanks for your help.
>>>MikeMc
>>>news:4950909@discussion.autodesk.com...
>>>This should be pretty straightforward. Here are the general
>>>steps/guidelines:
>>>1) Install a separate instance for Autodesk Data Management Ser
> ver
>>>(ADMS) -- it should be named "AUTODESKVAULT" (case is not important)
>>>2) Make sure you specify mixed mode authentication (the default choice
>>>is Windows only; this is NOT sufficient)
>>>3) For convenience, use "AutodeskVault" as the 'sa' password. This isn't
>>>absolutely necessary, but will streamline some operations in Vault
>>>Manager.
>>>4) Apply SQL Server SP3a BEFORE installing ADMS.
>>>Once you've done this, the ADMS installer should recognize and use this
>>>SQL instance
> instead of installing its own instance of MSDE.
>>>Cheers,
>>> Jeff
>>>MikeMc wrote:
>>>>I saw a post about installing Vault on a full SQL server, apparently
>>>>without the need to install MSDE first and then do an upgrade.
>>>>Can someone provide a link to a procedure for doing this?
>>>>I'm new to Autodesk and my VAR is not giving me much help in this area.
>>>>MikeMc
