I have been using Vault Pro 2013, and I'm getting familiar with Vault 2015. I noticed that the Get Command has changed either in 2014 or 2015. If I click on the folder view, the view does not automatically expand to show the complete folder location. Is there a "single click" option that I can do to fully expand the folder structure? I don't want to have to click the plus button 20 times to verify the correct folder location of files. I've attached a picture to better clarify. Thank you very much.
Daniel Hermanson
Solved by samuel.seah. Go to Solution.
Hello Daniel,
You can do a RMB->Expand->All to fully expand the folder structure.
Samuel
Hello Samuel,
That works. Thanks for pointing that out.
Daniel Hermanson
