Autodesk Vault Pro 2014 SR1 SP1.
Attempt to execute action/command "Roll Back Lifecycle State Change" to Item "B11NET11113" the only revision "0" of which is in Released state fails for the reason "There is no lifecycle state to roll back to".
How could this be possible?
Don't all Items have WIP state prior to be Released?
Solved by Maxim-CADman77. Go to Solution.
In theory, unless your files are set to a specific lifecycle state on creation. For example if you have it set up to Release a file on it's first check in... there would be no WIP to go back to.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
For Item this doesn't seem likely..... not sure what you're seeing. It does sound odd at best.
Chris Benner
Screenshots are always helpful. I don't disbelieve you by the way, I just have no idea what would cause this. Maybe one of the Adesker Vault gurus will have a thought.
Chris Benner
...not sure it would add anything to my textual description ... anyway ..that is how it looks for me:
Just had a thought... do you use ECO's? If so, do you have this checked?
Chris Benner
Ok,... that isn't the problem then, If that box was checked it would not let you roll back the state without an ECO.
Chris Benner
With the option enable, do you mean with that check box checked, requiring the use of an ECO? I don't think you can roll these back without the Administrator doing it.
I guess a good question would be, why are you rolling them back? Were they changed by accident? If so, then using Change Orders might help to prevent that. If users cannot change the lifecycle state without an ECO, they would be less likely to change them unless they are certain they need to be changed. My opinion.
Chris Benner
You can Change State (not roll back) without bumping the revision if that's the concern. When you change state from Released to WIP there is a check box for Skip Revision Bump. Good for quick changes that do not need a revision level change.
Chris Benner
For your Item Lifcycle rule of WIP to Released, is that set to bump the revision?
-Hywell
Looks like Item Purge command is responsible for this - http://help.autodesk.com/view/VAULT/2014/ENU/?guid=GUID-C3165C15-A4DF-4510-816F-A9B012413546
But then the command is very-very rough because unlike File Purge command it gives no any flexibility...
Thus user chould always chooce between keeping all the Item history and size of database (ability to purge historical versions of files that are blocked due to be linked to some historeical versions of Item).
Seems nothing can be done about it in the 2014 release (hope somebody could check if something was improved regarding this in 2015).
Have created the idea - http://forums.autodesk.com/t5/Vault-IdeaStation/Make-Purge-Item-Command-flexible-alike-Purge-command...
Hi Maxim,
just to recap and make sure I got you right:
You would like to rollback lifecycle State change of an Item from Release State to Work in Progress.
If this is the case today the Rollback Lifecycle State change can only be applied to an Item in Work in Progress state which has been at a certain time released. Please check also Vault help for that:
http://help.autodesk.com/view/VAULT/2015/ENU/?guid=GUID-A83D54E2-423A-450E-A6A5-4C6AEAD86F72
You can roll back an item that:
Rolling back an item from WIP to the previous released state deletes the current revision of the item.
The lifecycle of an item cannot be rolled back if:
