I’m trying to migrate projects into Autodesk Vault for the first time. I get a warning message the recommends using “Inventor Add-in.” I currently have existing “Type = Shared” projects I want to convert to “Type = Vault.” I tried creating a new project file with “Type = Vault" and that just gives me problems with the Mapping Folders in the browser. Either I get the “!” icon next to all Inventor files, or once I do map the folders, I can’t save the file back because it’s still check out by the “Shared” project and once I switch back to the “Shared” project, I no longer have the option to check the projects in. The closest I’ve come is when I create a “Type = Vault" project file is it’ll generate an empty folder in Vault Explorer. I don’t see how Inventor Add-ins can be used to send files to the vault. All I see is a list of services loaded or started in Inventor. I created a test project from scratch and had no problems setting it all up with the vault, but I can’t get my legacy data over.
Brent
Message was edited by: bbarbour
