Hi John,
Thanks for the information, very useful!
Does any of your sites have any of the following:
Exchange setup for Web access and SSL?
Product Stream setup?
Do you know the size limit for full SQL in SBS 2003?
Mark
"John Bilton" wrote in message
news:4948237@discussion.autodesk.com...
Whilst not being the ideal situation, I have a number of installations
working this way. If you have a dual Xeon server with 4GB
RAM and loads of space, you should be OK booting in 3GB mode.
Vault and Exchange have similar requirements, and you can set in SQL
Enterprise manager how mauch RAM and which processors to
prioritise for SQL - with HT dual Xeon, you have 4 virtual processors to
play with! Routine maintenance of the Vault installation
should keep the database fairly small, and routine restarting of the
Exchange stores.exe process and ASPnet Worker process should
deal with any memory leaks which both are prone to.
I have one site running SBS and full SQL with Vault on SQL. 9 full time
Inventor users, plus some AcadE users, Active Directory
supporting 25 users and a bespoke SQL system that runs the entire business.
Server is suitably beefed up and all is working OK.
HTH
John Bilton
