After installed Vault DataStandard, start AutoCAD (Mechanical) 2013, it will crash.
AutoCAD 2014 starts without problem, DataStandard plugin also works fine.
Try rename "C:\Program Files\Autodesk\ApplicationPlugins\DataStandard.bundle" folder, then start AutoCAD 2013, it will start without problem.
Can I change some registry value or configuration file to prevent DataStandard from loading for AutoCAD 2013? I think this extension is only designed for 2014, should not load for AutoCAD 2013.
Solved by Senthil_Kumar. Go to Solution.
The Data Standard 2014 Add-In is also loaded into AutoCAD 2013 because of the <RuntimeRequirements> setting in
"C:\Program Files\Autodesk\ApplicationPlugins\DataStandard.bundle\PackageContents.xml"
If you change the “SeriesMin” attribute to “R19.1” the Add-In should not be loaded into AutoCAD 2013:
