Gang...
Attempted to test out the Web Client for 2015, but the URL doesn't seem to work.
Here's what I typed in for my browser, but says it's an invalid site.
Trying to access web client from same machine where ADMS is stalled.
http://servername/AutodeskTC
I set the servername above to my computer name where 2015 ADMS is installed. I tried name and IP address....both error.
Any thoughts?
Solved by DarrenP. Go to Solution.
the web client is a separate install now
run setup.exe again and click on install tools & ultilities
DarrenP
i found this out because i needed the network license manager
DarrenP
Thanks....that did the trick.
You will have to run the setup.exe from the ADSM server just once.
FYI...You don't have to worry about clients.
