Discussion Groups
Simulation Mechanical and Multiphysics
New Member
Airfoil Wing Analysis in Algor?
254 Views, 1 Replies
04-29-2012 05:31 AM
I was wondering if anyone knows the best way to apply a load or wind or temperature or something to generate results for analysis on a airfoil.
Any help on how to work with this software would be beneficial!
Thank you.
Please use plain text.
Employee
Joey.X
Re: Airfoil Wing Analysis in Algor?
04-30-2012 05:48 AM in reply to: vferdin
For fluid wind load,
- Make fluid domain (fluid part) and set up fluid analysis as external flow (make airfoil inside box and set appropriate BCs).
- Run fluid analysis to get fluid reaction force contributed from pressure and stear stress on surface(s)
- (In structure analysis) read fluid reaction force for stress analysis
For temperature loads, do thermal or coupled fluid/thermal analysis first to get temperature distribution and apply as loads in structure analysis.
Jianhui Xie, Ph.D
Principal Engineer
MFG-Digital Simulation
