dear sir
kindly find attached file
1-he define composite column ( concrete 500*1000 mm included UB 610X305X238 ) in section definitions
but i have problem in design for this case
( capacity value is too high see pic1)
2- kindly i want to know more about section definition analysis and design it in robot
i read help but it is not enough.
Regards
Solved by Artur.Kosakowski. Go to Solution.
Such sections can be used in a model for static analysis, you can check stress distribution in the Stress Analysis module but the design (code checking) of such section is not supported in Robot.
Dears:
Good day
Please advise how to define Composite column in Autodesk robot structural analysis
Regards
