Hi.
Anyone got any suggestions on how to implement wave loading on a structure in Robot? I'm guessing through API?
I'm thinking I'll need an API that defines a time history case to apply loads to multiple members simultaneously.
Any help welcome!
Tony
Tony,
You can try to use body force load types available in Robot or the devoted part of Robot Extension Spreadsheet Calculator (mind that W7 64bit is not supported by the RESC wave load generator).
Thanks Artur,
Problem is, all of our PC's at work just got upgraded to Win 7 64 bit
So..........is there a work around?
Tony
I'm sorry I meant W7 64bit and MS Office 2010 both 32 and 64 bit (no workaround available).
The generator should work on W7 64bit and MS Office 2007.
OK.
It seems to be fine on Win 7 64 bit with office 2010 32 bit.
The only problem is the graphics screen flickers alot and is not really readable. Some of the input dialogue boxes remain "locked" in the graphic viewer too. But otherwise it works OK.
If you are able to import a model from Robot then you are the only person I know who is so lucky. Perhaps this is due to the fact that your part of the world is 'upside down'
hahaha
It imports, but the screen flickers like crazy and makes you go mad
But it seems to export out the loads back into Robot
Only works at home though, not at work....................
Mate to be honest I gave up trying to make it work as the whole thing got a bit hard. I don't do wave loading in my work anyway but was investigating it for some colleagues.
My thoughts / suggestions;
Sorry I couldn't be more help.
Tony
Try to replace the original dll with the attached one (C:\Program Files\Autodesk\Autodesk Robot Structural Analysis Professional 2013\RESC\Engineering\lib\00\ROBOT). This should allow you to import a model from Robot and generate wave loads back in Robot but will not solve the model display issue in SC.
Tony and Andy,
Am I right in assuming that the file I attached allowed for importing models from Robot the the wave loader sheet?
Thank you for confirmation
Artur,
I replaced the dll as instructed.
The model imports beautifully from Robot and all the wave load parameters are able to be editied.
It seems to be working well.
Problems;
So yes it works well.
Still not 100% bug free though.
Thanks a lot
Tony
Thank you Tony. As I wrote the file I posted is not intended for solving the display issue. I'm pleased to hear that it works for data exchange.
Artur,
Can you publish help to this spreadsheet if it exist? Thank you.
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
If you have RESC installed then check C:\Program Files\Autodesk\Autodesk Robot Structural Analysis Professional 2013\RESC\Engineering\help\44\ROBOT\44ROBOT_COM_014\44ROBOT_COM_014.htm
Otherwise see the attached pdf.
I need to calculate Wave load on a structure. I read this post but couldn't find the spreadsheet. My Robot version is 2015.
