Hi.
It is possible to calculate a close to exact critical force for flexural buckling using the buckling analysis. Is it similarly possible to calculate critical forces for buckling modes listed in the subject? All I've seen so far are calculations using procedures described in different codes that are simplified at best.
Thanks in advance.
Solved by Artur.Kosakowski. Go to Solution.
For bar model it is not possible. You need to model a steel profile as panels in a shell model type instead.
You need to determine the kind of buckling by the shape of the buckling mode.
