Slab punching check
3 REPLIES 3
632 Views, 3 Replies
Slab punching check
slab punching check for the slab shown in the pictures.
The difference from pictures 1 and 2, is that the columns angle changes by 90 degrees, and that affects the punching perimeter of the edge and corner columns, since the slab continues over the edge columns X-direction 0.6m and Y-direction 0.3m
3 REPLIES 3
Artur.Kosakowski
Attach the rtd file please?
Artur Kosakowski
in reply to: Artur.Kosakowski
the file.
Artur.Kosakowski
The display (orientation of the panel) in the RC Design viewer can be different than the top view of the model and depends on the local X of the panel. As far as I can see the columns are 'exported' as they should be. You can check looking at the numbers of nodes displayed in the brackets (2) - (4) etc.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
