Discussion Groups
Robot Structural Analysis
Active Member
eiriknor
Accepted Solution
Shear considered in column calculations
355 Views, 6 Replies
02-28-2013 06:11 AM
I turn on "Shear considered" when I calculate a column, but then get the message "Unsatisfactory load capasity of the column." When I look at safety factors it says VRd/VSd = 0,00, see the attached file. I guess that means VRd = 0 kN, that again means that the column have no shear capasity at all, this must be wrong?
Eirik
Please use plain text.
Product Support
Re: Shear considered in column calculations
02-28-2013 06:47 AM in reply to: eiriknor
File please
Rafal Gaweda
Active Member
eiriknor
02-28-2013 08:48 AM in reply to: Rafal.Gaweda
Here you go.
Product Support
Artur.Kosakowski
03-01-2013 07:13 AM in reply to: eiriknor
Try to force the use of 32mm bars as main reinforcement.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
Active Member
eiriknor
03-02-2013 11:28 AM in reply to: eiriknor
OK, that solved the problem. But isn`t this a bug? If I set the corner bars diameter to "Auto", shouldn`t Robot figure this out self?
Product Support
Artur.Kosakowski
03-03-2013 11:22 PM in reply to: eiriknor
I have checked on the pre-release version of  Robot v.2014 and it does :smileyhappy:
Please note: Our quality assurance teams may need to reschedule some fixes. Please rely on the above timeline information as a guideline only and not a guarantee. We appreciate your understanding in this matter.
Artur Kosakowski
Active Member
eiriknor
03-05-2013 01:26 PM in reply to: Artur.Kosakowski
Love to hear that, keep up the good work.
