Is there a way to convert my current robot model into a revit model?
I can see discussions on revit to robot but not vice versa.
K
Solved by Artur.Kosakowski. Go to Solution.
You export model from Robot to Revit in the same way as you update a Revit model after sending it to Robot first.
http://forums.autodesk.com/t5/Robot-Structural-Analysis/Integration-REVIT-lt-gt-ROBOT/m-p/3336591
