I am facing problem Autodesk Robot Structural Analysis Professional 2014
which is one of the software at Autodesk Infrastructure Design Suite
Ultimate 2014.Which installed in laptop.
The problems were :
1.To Design RCC(Reinforcement Cement Concrete)structure when i click the
Reinforcement pattern option the laptop are hang.
pic 2.jpg-image/jpeg(262 k)
When it is hang there is no other option to restart the computer.
2.when i select the beam & open the beam option it open the foundation
option.
Foundation.jpg -image/jpeg(205 k)
3.Some other problem I also face.I cannot understand those problem but i
give those snap.
pic 3.jpg-image/jpeg(265 k)
I am moving thread to the Robot Board as they have a better understanding of feature related issues.
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
Try to reduce the hardware acceleration (http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Robot-2014-plate-not-displaying/m-p/3894242) and delete the temporary windows file.
You may also try to rename the CfgUsr folder (e.g. to 1_CfgUsr) located in C:\Users\username\AppData\Roaming\Autodesk\Autodesk Robot Structural Analysis 2014 folder.
Hi there,
I am having the same problem with my robot structural analysis. Everything runs fine until i attempt to do reinfircement design. More example, if i click on "Reinforcement patterns", it brings up a windows installer prompt as if the proram is attempting to installing something but the installer just hooks for a long time.
I have attempted both possible solutions in this post but i was hoping there could be anothe solution? Kindly help.
