it seems that no matter what I try (various meshng methods, size etc.) I cannot get a proper mesh for the walls of the attached model.
Moreover If I particularly select one of the walls with meshing issues and then delete its mesh, then I get other walls mesh also deleted... very awkard...
I already spent a lot of time trying to figure it out, so I though sharing this issue here would be helpful.
thanks for any input.
I'm using Robot 2013 under windows XP
Solved by Artur.Kosakowski. Go to Solution.
Thanks you very much
I don't know how to fix error 1
please help me
I asked for more: How to progaming VBA between Excel and ROBOT
Thanks you
This is my file, in link below
http://www.mediafire.com/?540c635cs8dhbj9
Thanks you veryyy much
I am looking for learn Rsap &Revit from you
Can you help me okay?
Thanks you very much again
I have the same problem: I have a model with different size of the mesh(same larger and other smaller): how can I obtain regular mesh' dimensions for all the elements?
When I try to mesh one part all the model take the same mesh.
Is it correct to use these options?:
in TOOLS , JOB PREFERENCES , MESHING: Kinematic constrains
In ANALYSIS, MESHING: Meshing Method, authomatic selection, size (and I insert the size I want)
Probably there is something in my procedure that is incorrect.
I have attached the model here below
Select the panel , click on "meshing options" icon and set whatever you want for only this selected panel
Rafael Medeiros
