Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Lateral displasement
10 REPLIES 10
Message 1 of 11
oyvinkle
666 Views, 10 Replies
Hey! I am trying to model a building and I only want the lateral displacement off the floors to be present for the modal analysis. How may I proceed? I have used shell elements for the walls and ridged diaphragms for the floor.  When I use this kind of modeling the floors can rotate and I get an axial deformation in the walls…. Please help!!
10 REPLIES 10
Message 2 of 11
Rafal.Gaweda
in reply to: oyvinkle
 Massses in XY direction only?
Rafal Gaweda
Message 3 of 11
oyvinkle
in reply to: Rafal.Gaweda
One modal analasys for the X directrion and one for the Y.. The pic. is the first mode in the Y dir.
Message 4 of 11
Rafal.Gaweda
Send me model please
Rafal Gaweda
Message 5 of 11
oyvinkle
do you have an e- mail it seems the file is to big ore i ant copress it corectly
Message 6 of 11
Rafal.Gaweda
use www.wetransfer.com or www.filemail.com service or any similar then post link here or in private message
Rafal Gaweda
Message 7 of 11
oyvinkle
Message 8 of 11
oyvinkle
The file was postet. can you open it?
Message 9 of 11
Rafal.Gaweda
How do you think?
From where do I have model to show you errors http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Mesh-consetration/td-p/3763970 ?
Calm down , I will look
Rafal Gaweda
Message 10 of 11
oyvinkle
Smiley Happy sorry about that I did not meen to be so blunt!
Message 11 of 11
Rafal.Gaweda
As far as we understood your desire it is rather not possible to obtain (maybe with adding additional supports...)
Take a look at attached screen shot. This is an example of wall subjected to act only in Y / Z directions (supports blocking X in all nodes defined). So for such simple model you get "axial" wall deformation.
BTW: do not you think you should use Membrane diapgragm rather then Rigid?
Of course it is your choice, just my remark.
Rafal Gaweda
