Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Hollow core slabs and seismic
7 REPLIES 7
Message 1 of 8
743 Views, 7 Replies
can anyone tell me is it possible to do modal analysis and seismic calculation with hollow slabs in construction model?
Thank you very much.
Ivana
7 REPLIES 7
Message 2 of 8
Rafal.Gaweda
Yes, it can be calculated.
Rafal Gaweda
Message 3 of 8
Thank you for your answer. I've already defined hollow slab in my model but during analysis error 902 appears. After that I changed the slab into homogeneous (just for check) and no errors showed, calculation was fine. I thought maybe self weight of hollow slab is not converted to masses?!
Message 4 of 8
Rafal.Gaweda
Error description :
http://docs.autodesk.com/RSA/2013/ENU/index.html?url=filesROBOT/GUID-8E8ED7A4-9A55-4F1F-8771-7E1A9CE...
902
Negative eigenvalue has been obtained
PLease send me model to check
Rafal Gaweda
Message 5 of 8
in reply to: Rafal.Gaweda
Here is the model. (Original model is too big to send so I made a little example)
Thank you.
Ivana
Message 6 of 8
Rafal.Gaweda
Ivana,
Take a look below. You have defined wrong geometrical properoes of holes in holow slab.
Opening bottom edge is 2mm below slab bottom layer
ho/2 = 160 and hc=158 -> ho must be less or eq to 316
Rafal Gaweda
Message 7 of 8
Rafal.Gaweda
To help you checking : matrix values can not be negative
Rafal Gaweda
Message 8 of 8
Yes, that was the problem. Thank you very much!!
Ivana
