Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Foundation Results (RSAP 2013) - missing view
7 REPLIES 7
Message 1 of 8
memoalcr
1017 Views, 7 Replies
Dear Support,
When checking Foundation Results, the plan view with the stress distribution does not display (see attached file). Why?
7 REPLIES 7
Message 2 of 8
Artur.Kosakowski
in reply to: memoalcr
Try to use: Tools > Customize > Open Layouts from template and calculate the foundation again. If this doesn't solve this issue attach the rtd file please.
Artur Kosakowski
Message 3 of 8
memoalcr
in reply to: Artur.Kosakowski
Mr.Kosakowski, The procedure did not work. Please download the rtd file form https://www.yousendit.com/download/UW13blFNckllaFNLRmNUQw -- Ing. Guillermo Alvarez III (IC-9105) Tel: +506 2220-2710 Fax: +506 2220-2722 www.sismocon.com
Message 4 of 8
memoalcr
Procedure did not work. Please download the rtd file from
Thank you
Message 5 of 8
Artur.Kosakowski
I can't see such problem on my computer. Try to delete the foundation from the Inspector and import it again from the model.
Artur Kosakowski
Message 6 of 8
memoalcr
I tried your suggestion and nothing. I ran new model and obtained the same resutls. My PC runs Windows8.
I did put the model on another PC with Windows7 and the view does appear.
Could it be an OS error?
Message 7 of 8
memoalcr
Mr.Kosakowski, if I  close the window with the global coefficients, design combinations, etc. the plan view with the stress distribution does display (see attached file). Any suggestions?
Message 8 of 8
Artur.Kosakowski
Robot 2013 is not officially supported on W8. There may be some issues as it has been released prior to W8.
Artur Kosakowski
