In my Revit model I've defined a new floor section which has 50cm thickness. I've assigned this section to the floors which were previously 40cm in thickness. Send the model to robot and find out that that floors passed as 500cm! I've tried in different computers with same outcome. Can you please validate the error, I'm sending the model files with the link below.
section name D500-B60
floors in revit (191421,201323,735187,741787,747494)
floors in robot ( 104 107 7115 7651 7652 )
http://share.stand.com.tr/public/4d65f8.php
Thanks for your helps.
Hi Rafal,
how could this happen I really don't understand, never experienced such an error before.. And it makes me even more confused that on your side transfer is without errors. do you have any idea what can cause such a behaviour??
I think Leader_Mohamed may have a point !
previously I've created a simple robot model and defined a section with the same name for a trial run (than erased that model). and it was a completely separate file from the original model that I have the current issue.
I guess, somehow, that section name with its erroneous properties, carried on to the original model which was transfered from revit. Does robot have a database file of sections seperate from the model file stored somewhere else?
