Discussion Groups
Robot Structural Analysis
New Member
Ferraillage d'une poutre courbé?
281 Views, 3 Replies
01-15-2013 09:27 AM
Bonsoir a tous. je voudrai savoir pour le ferraillage d'une poutre courbé comme le montre la figure en dessous:
es-que RobotSA peut la ferrailler ou pas et comme le faire dans le cas ou il ne peut pas? Merci
Please use plain text.
Product Support
Artur.Kosakowski
Re: Ferraillage d'une poutre courbé?
01-16-2013 12:02 AM in reply to: mohamedx61
For bent beams you should use the RC Members Required Reinforcement module. Such beams are currently not supported in the RC Beam Reinforcement module.
Artur Kosakowski
11-21-2013 12:18 PM in reply to: Artur.Kosakowski
mais pourquoi nous n'avons pas se probleme losque nous exportons une poutre courbe a partir de cbs?
Product Support
Artur.Kosakowski
11-22-2013 02:13 AM in reply to: judicaeltapsoba
I think we are discussing two different situations:
- definition of  a curved beam in a model of a structure which can be done as chain of small straight elements forming a arch
- calculations of provided reinforcement in the RCA Beam design module which is currently not supported in Robot
Artur Kosakowski
