Discussion Groups
Robot Structural Analysis
Valued Contributor
pevelor
Accepted Solution
Diagram for walls
452 Views, 6 Replies
12-04-2012 04:43 AM
Hi
I want to use a diagram illustrating the vertical load applied to a wall.
So far, I have only been able to use maps and thick of membrane forces.
Moreover, I want to find an average value or integral value.
Can someone please help me with this?
Kind regards
Peder
Please use plain text.
Product Support
Artur.Kosakowski
Re: Diagram for walls
12-04-2012 04:59 AM in reply to: pevelor
Peder,
Could you attach a sketch which illustrates what the diagram should look like please?
Artur Kosakowski
Valued Contributor
pevelor
12-11-2012 02:57 AM in reply to: Artur.Kosakowski
Hi
I diagram looking like this would be nice
Is that possible?
Regards
Peder
Product Support
Artur.Kosakowski
12-11-2012 04:11 AM in reply to: pevelor
Here you are.
Artur Kosakowski
Valued Contributor
pevelor
12-12-2012 01:00 AM in reply to: Artur.Kosakowski
Thanks Artur.
Would it be to much to ask if you could make a short video illustrating how you would do this in structure type 'Building design'?
One reason I want to check these values is to investigate the minimum thickness of a wall in regards to just compression.
Product Support
Artur.Kosakowski
12-12-2012 01:16 AM in reply to: pevelor
Here you are.
Artur Kosakowski
Valued Contributor
pevelor
12-12-2012 02:02 AM in reply to: Artur.Kosakowski
supernice.
Thanks a lot
