Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Detailed and Principal Moment/Shear Results for Plates
1 REPLY 1
1811 Views, 1 Reply
Guys,
I am modeling a turbine foundation as a 2d plate model on an elastic subgrade. I am currently reviewing the results and notice that the results for moments and shears differ depending on whether the 'detailed' or the 'principal' results are selected within the the panel maps results tab.
What is the difference between 'detailed' and 'principal' results in Robot panel map tab?
Also in 'principal' results what is the difference between 1, 2, 1-2? Do these correspond to an axis direction?
Dave
1 REPLY 1
Artur.Kosakowski
http://docs.autodesk.com/RSA/2013/ENU/filesROBOT/GUID-1279D686-429D-46F7-AE21-7E37F65C4D12.htm
http://docs.autodesk.com/RSA/2013/ENU/filesROBOT/GUID-BD23B817-BEE0-4DB2-97AF-2571B877F803.htm
Artur Kosakowski
